Date/Time: Fri, 07 Feb 2025 18:01:08 +0000
[User Discussion] - TT
View Count: 897
[2020-06-10 09:38:35] |
User480295 - Posts: 12 |
Hi I would like to use trade Bursa Malaysia futures contract using TT feed through Sierra Chart. Sierra Chart / Trading Technologies Futures Order Routing Service Is it possible bec Bursa Malaysia is not one of the supported exchanges by Sierra Chart. Thanks. |
[2020-06-10 09:49:11] |
It is not a problem for us to add that exchange. We will get back to you in a couple of days on this. The only consideration which might make it difficult is the market data.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-10 09:51:27
