Date/Time: Fri, 07 Feb 2025 18:02:01 +0000
Replay chart doesnt work tick by tick
View Count: 884
[2020-06-10 01:03:34]
User264055 - Posts: 8
even if data is saved tick by tick, the replay chart displays the bars only at close per second and not tick by tick
replay mode is "calculate same as real time"
"Enter Processing Step in Seconds" is chosen 1 or 0.001
l re-downloaded data
l have tried all below instructions
https://www.sierrachart.com/index.php?page=doc/doc_ReplayChart.html#HistoricalIntradayDataRecordTimeframeEffect
https://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php
[2020-06-10 10:49:11]
This looks like a multi-chart replay and in this case the minimum processing step is 1 second.
[2020-06-10 12:02:03]
when l use single chart replay but it still displays the bars only at close per second and not tick by tick
also when l use method of jump by number of trade (1) or by time (1ms) it works very nice
can you kindly help me to use replay chart tick by tick
[2020-06-10 18:15:50]
This will be improved upon when true millisecond time stamping for trades is added over the next month or so.
