Date/Time: Fri, 07 Feb 2025 17:10:15 +0000
How to trade an account with data from other source
View Count: 539
[2020-06-09 16:35:36] |
Jochen Penther - Posts: 7 |
I tried to setup sierrachart for example to trade an account at AMP Futures. I have good data at interactive brokers and want to use these data for charts. But i cannot setup both together. Each alone works fine. But trading and data are different things, so why i cannot trade with the broker of my choice with the data of my choice? Have i overlooked something in documentation? Can you help me to setup? Thanks in advance.
[2020-06-09 18:13:07] |
When trading through AMP you will want to use the Sierra Chart order routing service which works with the Sierra Chart Data feeds which are very reliable and easy to use: Sierra Chart / Trading Technologies Futures Order Routing Service We cannot help with Interactive Brokers as we have terminated technical support for that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
