Date/Time: Fri, 07 Feb 2025 18:26:53 +0000
240 CHART GOING BACK TO YEAR 2000
View Count: 631
[2020-06-09 16:28:30] |
User480008 - Posts: 4 |
I HAVE BEEN BACK TESTING ON A 240 CHART AND HAVE FOUND THAT IT WILL NOT LET ME GO PAST 12/03/2007. IS THERE A WAY TO GO PAST THAT DATE FOR BACK TESTING. I CAN GO PAST THAT DATE FOR HISTORICAL ON A DAY CHART BUT NEED TO GO PAST THAT DATE FOR 240 CHARTS ON EURUSD.
[2020-06-09 18:09:34] |
No we do not have Intraday data available earlier than that for the Forex symbols. You will need to find another source of the data and import it: Exporting and Importing Intraday Data Files Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-10 18:15:48] |
I NEED REMOTE SUPPORT WITH CHARTS
[2020-06-10 18:17:30] |
MY CHARTS 240 MINUTE WERE GOING BACK TO 12/03/2007 AND NOW THEY ARE ONLY GOING BACK TO 12/19/2014
[2020-06-10 18:31:02] |
Refer to this section here related to this: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
