Date/Time: Sat, 19 Sep 2026 21:04:55 +0000
Cancel Order button disappears in DOM when Hide Values Scale is enabled?
View Count: 927
| [2020-06-09 14:42:09] |
| j4ytr4der_ - Posts: 947 |
I'm not sure if this is a bug or there's an option somewhere I can't find. I'm using a Trade DOM, and do not want to display price. So I enable Hide Values Scale and the price goes away. That's great. But what also goes away, is the little "X" we can click on, to cancel any pending orders in the DOM. This is only visible if the Values Scale is shown. Is there a way to keep this from disappearing? |
| [2020-06-09 17:28:50] |
We are not able to reproduce this. Can you please include a screen capture of what you are referring to?
| [2020-06-09 19:51:31] |
Sure thing. It was also mentioned here in this post: Dom price displayed | Post: 215133 I have attached 2 images, one with the values hidden and you can see there is no way to delete the resting order. The other with the values shown, clearly shows the "X" you can click, to delete the order. |
| [2020-06-12 19:04:00] |
Looks like this has been fixed as of 2118. Thank you!!
