Date/Time: Fri, 07 Feb 2025 18:20:19 +0000
Plot data for 2 different symbols onto one chart
View Count: 1884
[2020-06-09 11:33:47] |
User629461 - Posts: 184 |
Hi, is it possible to plot price data for 1 symbol and volume for another symbol on the same chart. For example, I want to plot Spot Forex price data (eg AUDUSD) but with the Forex Futures volume (CME contract 6A) on the same chart, instead of using forex volume as its inadequate. Another example would be plotting an Index CFD's price data but with the underlying Index Future's volume. This can be done on other platforms but not sure if its possible on SC. Thanks.
[2020-06-09 18:24:15] |
Yes this is supported. Refer to: Add Additional Symbol You can then add a Volume study to the chart and base it on the Add Additional Symbol study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-10 04:43:21] |
Great, thanks for that. I constructed the chart as istructed but seem to have a problem with the volume data displaying correctly for symbol that has been added. In the attached picture, the left chart is a Futures chart with futures volume and zig-zag study. On the right, the base chart is a CFD chart with the Futures chart added as instructed. Futures price data is displaying accurately, however at the very bottom the futures volume is not displayed correctly. Any thoughts on what might be wrong?
Picture1.png / V - Attached On 2020-06-10 04:43:03 UTC - Size: 539.04 KB - 521 views |
[2020-06-10 05:08:48] |
You need to update to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
