Date/Time: Fri, 07 Feb 2025 17:01:39 +0000
OHLC from OutsideBar
View Count: 610
[2020-06-09 11:27:38]
User354816 - Posts: 21
I would like to refer to the OHLC values from the outside bar study.
But it seems only the High of this bar is outputed to the subgraph ?
How can I get these values ?
Thank you !
[2020-06-09 12:00:31]
Ackin - Posts: 1865
It's not hard, rather write what you need to do with it. Projection using OHLC points / lines into the future? A certain number of projection bars?
[2020-06-09 15:30:27]
Hi Ackin,
I would like to project the extend high/low from the outside bar until further intersection. These Lines need to be a subgraph that I want to refer to in other charts.
[2020-06-09 15:33:14]
Ackin - Posts: 1865
Hi, Should I do it as a study?
