Date/Time: Sun, 13 Sep 2026 20:19:14 +0000
Number Bars Calculated Values subgraph Volume/Sec returns result in strange format
View Count: 856
[2020-06-09 10:56:11]
User623005 - Posts: 12
Hi, having strange numbers only in F.US.TYAU20 and F.US.USAU20 symbols(US treasuries)- seems like it somehow is using 1/32 format instead of 0.1. Any other instruments I use show this subgraph correctly. Please advise
Private File
Private File
[2020-06-09 14:36:07]
John - SC Support - Posts: 47854
This is happening because we use the Value Format of the main price graph for those numbers (and a few others). We will put together a solution and have it out in the next release.
[2020-06-10 16:09:10]
We have this fixed and changed it so those values that should be displaying with values after the decimal will always have at least 2 digits after the decimal.
This will be in the next pre-release (v 2120). When available you can upgrade using the Fast Update option:
