Date/Time: Fri, 07 Feb 2025 17:14:15 +0000
DOM click responsiveness
View Count: 758
[2020-06-09 02:01:52]
Tahir - Posts: 35
I've been using Jigsaw as my go-to DOM and recently decided to try out Sierra DOM. I think it's a lot better in many ways but I'm getting quite slow response time. I scalp so I'm in and out quickly. SC DOM seems to be quiet slow at responding to my clicks. If I want to enter 3 lots I click 3 times really fast but almost all of the time I would get 2 clicks registered max. There seems to be about 1-second delay. Everything else works fine and responsive. I have a very fast computer with 32gb ram I7 processor etc.
I use rithmic data. I'm aware you are not supporting rithmic data anymore, could this be something to do with that? If so would you be able to give me a demo for any other data provider you do support?
Thanks for the support.
Tahir
[2020-06-09 02:17:08]
First we want you to update to the very latest release:
And then reduce the Chart Update Interval for the Trading DOM to 200 ms:
Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu)
And also refer to:
Chart Trading and the Chart DOM: Double Click Operations in Order Entry Columns
For demonstration of our own data feed, use the Sierra Chart Delayed Exchange Data Feed:
Date Time Of Last Edit: 2020-06-09 02:18:37
