Date/Time: Fri, 07 Feb 2025 16:47:58 +0000
Dom
View Count: 578
[2020-06-09 02:00:53] |
aurel88 - Posts: 8 |
Bonjour est ce possible de booster le dom de le rendre plus rapide? Merci
[2020-06-09 06:04:21] |
Refer to: Chart Trading and the Chart DOM: Improving Performance of Trading DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
