Date/Time: Fri, 07 Feb 2025 17:01:16 +0000
SC Future order routing vs SC Data all services
View Count: 1199
[2020-06-09 00:36:31]
User169687 - Posts: 7
please I would like to know as follows:
- the connection for real-data feed is the SC Future order routing, whereas the SC Data all services is for the delayed historical data. is it correct?
- Can I trade from both connections or only from the SC Future order routing connection?
- I have seen in the top menu: File -> instance, what is the purpose of a new instance.
Thank you.
[2020-06-09 02:46:32]
Both of those services support real-time data. You need to use SC Futures Order Routing for live trading for futures.
For documentation for new instances, refer to:
Using DTC Server for Data and Trading in Another Sierra Chart Instance
[2020-06-09 10:09:45]
Thanks.
SC package 3 with SC Data all services connection provides real-data for forex and CFD, I believe that this is freely available.
If I want to trade as well forex and CFDs can I use the data provided by SC Data all services connection using AMP trading.
[2020-06-09 19:39:43]
You will need to change your Sierra Chart service package with AMP to the Advanced package 5 to access the Forex and CFD data. And it will be accessible when using the SC Futures Order Routing Service.
Date Time Of Last Edit: 2020-06-09 19:39:50
[2020-06-10 01:18:16]
Ok. Thanks.
