Date/Time: Fri, 07 Feb 2025 16:47:58 +0000
how do you stop order executions arrows from disappearing from charts
View Count: 632
[2020-06-08 22:52:24] |
User540754 - Posts: 34 |
thanks in advance for your help on this. i have "show order fills" checked yes via execution arrows on my charts. but every evening all of the arrows go away. is there a setting i am not aware of? tried search function on this support board, but it showed 0 results. appreciate your help! |
[2020-06-09 02:48:37] |
You need to uncheck this option: Chart Settings: Load Order Fills for Current Day Only (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-09 17:22:14] |
Thank you!
