Date/Time: Tue, 15 Sep 2026 18:36:16 +0000
[User Discussion] - Analyis / Studies
View Count: 1596
[2020-06-08 17:38:30]
User660345 - Posts: 18
Good day
I would like to receive an additional arrow to the MACD Crossover System which is already available in the available studies. If the green signal line SG1 crosses the MACD zero line SG4 from bottom to top there should be an arrow pointing upwards. Similarly, if SG1 crosses SG4 from top to bottom, there should be a downward arrow.
Can you please send me the programming formula? Many thanks and best regards
[2020-06-08 18:36:36]
Ackin - Posts: 1865
MACD source code (Acsil):
https://www.sierrachart.com/downloads/1580/ACS_Source/systems.cpp
MACD Crossover System documentation
Similar forum threads for Alerts, Spreadsheet:
MACD Crossover Alerts
formula for MACD crossover system in spreadsheet
Study: Color Bar Based on Alert Condition
Date Time Of Last Edit: 2020-06-08 18:41:14
[2020-06-09 08:44:05]
Good day
Thank you very much for your answer. I have downloaded the file and inserted it into the Sierra Chart folder. Unfortunately the file does not open there. It also cannot be inserted into the two Sierra ChartStudies folders.
What am I doing wrong? Unfortunately I am not able to write my own program.
Therefore I have to ask you again for help. I would like to have an up or down arrow displayed when the fast MACD line crosses the MACD zero line from below up or from above down with the closing price.
Thank you very much for your effort and best regards
Novice92
Translated with www.DeepL.com/Translator (free version)
[2020-06-09 10:51:24]
Ackin - Posts: 1865
The attached Study Collection provides a working example.
Follow the instructions here to use this Study Collection:
How to Use an Advanced Custom Study or a Study Collection: How to Use a Study Collection
The Study Collection uses the Color Bar Based on Alert Condition study to color the bars when the condition is met.
attachmentMACD cross.StdyCollct - Attached On 2020-06-09 10:50:47 UTC - Size: 37.3 KB - 444 views
[2020-06-09 13:05:12]
Good day Ackin
Thank you very much for your answer and the indicator. I was able to insert the indicator based on your information and it shows me exactly what I want to see.
Best wishes and a nice day
novice92
[2020-06-11 07:40:37]
Good day Ackin
I am a little frustrated, I spent several hours trying to recreate your MACD CROSS indicator with the "small vein" that there is an arrow below or above the bar when the MACD crosses the zero line.
Songs I have not been able to do ☹ . It always comes the error message #ARGS!
I also read the descriptions of "Color Bar Based On Alert Condition" which unfortunately didn't help me either.
What do I have to do to get the MACD CROSS with arrows instead of the Background Trans...please?
Thank you very much for your help once again.
Kind regards Novice
[2020-06-11 08:04:03]
Ackin - Posts: 1865
Take a look at the attached file
Date Time Of Last Edit: 2020-06-11 08:05:02
imageColor bar settings.png / V - Attached On 2020-06-11 08:03:29 UTC - Size: 196.79 KB - 450 views
[2020-06-11 09:19:26]
Hi,:)
So... when I make these settings I get a line with the arrows but the bars are gone
I wanted to attach you the current chart as a file unfortunately I can not.
Is it possible that we can discuss the problem by phone and remote assistance?
My telephone number is 0041 33 335 09 19
Thank You
[2020-06-11 09:26:30]
Ackin - Posts: 1865
Hi, I am not the official support of this platform (Support has the nick Sierra Chart Engineering or SC support). I write it so that there are no misunderstandings about who is writing to you. I'm a regular user like you.
If you have another problem or are trying to transfer it to another study, open the "alerts" tab. There you see the formula.
If you want to create a complete study of where everything will be in one, it is possible, free, register on the czsk forum. There is more space to discuss around it and I am not alone in helping others. There are more willing people, If I don't know, someone else will advise you. There are also more similar studies where the alerts are already integrated directly into the study. The user just changes the items in the settings.
contact link:
Date Time Of Last Edit: 2020-06-11 09:29:00
[2020-06-11 09:33:33]
I understand, thank you very much in any case :). It always takes a bit longer because I always have to translate everything. Yes I will hold on... And again thank you very much and best regards
