Date/Time: Fri, 07 Feb 2025 17:06:10 +0000
DOM header
View Count: 924
[2020-06-08 16:51:13]
User495158 - Posts: 108
Hi!
Is it possible to remove DOM header "Symbol - chart number"? I have tried in Global settings/ Customize chart header - trade DOM but it keeps reappearing.
Screenshot included.
Thanks.
imagedom_header.png / V - Attached On 2020-06-08 16:51:06 UTC - Size: 30.57 KB - 241 views
[2020-06-08 19:09:18]
So you do not want any header fields displayed?
[2020-06-08 19:44:58]
Yes, I want to remove all header fields.
[2020-06-09 06:27:32]
You need to have at least one of the fields. Update to the very latest release and add at least the Trading Locked Indicator field.
