Date/Time: Fri, 07 Feb 2025 16:53:16 +0000
Automatic linking of Trade and Current Quote Symbol
View Count: 776
[2020-06-08 15:53:10] |
skelcap - Posts: 139 |
Is there a way to link a Trade and Current Quote Symbol to a main symbol, so that when you enter the main symbol in the chart it automatically loads the linked Trade and Current Quote Symbol? I tend to type the main symbols quickly on the chart to switch markets and it takes time to have to keep looking up the long Trade and Current Quote Symbol in the Find Symbol window. I'm doing this for trading Forex with Interactive Brokers on the chart.
[2020-06-08 17:54:26] |
You can set a Trade and Current Quote Symbol in the Global Symbol Settings. Refer to the information here: Global Symbol Settings: Symbol Settings And also refer to the following information for how to update a symbol setting: Global Symbol Settings: Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
