Date/Time: Fri, 07 Feb 2025 17:26:21 +0000
[User Discussion] - alert
View Count: 558
[2020-06-08 15:31:30]
Robert Wojczak - Posts: 147
1) How do I get an audible alert to sound when my order is filled?
2) How do I use a custom I alert sound that I want to use?
Thank You
[2020-06-08 15:35:45]
Ackin - Posts: 1865
try:
Global Trade Settings Windows: General Trade Settings
Menu >> Global Settings >> General Trade Settings
note
If you don't hear alerts then check this:
Globally Mute Alert Sounds
To globally mute (prevent from playing) all alert sounds, check the menu option Global Settings >> Mute All Alert Sounds. Uncheck this menu option to un-mute the sounds.
Date Time Of Last Edit: 2020-06-08 15:42:11
