Date/Time: Fri, 07 Feb 2025 16:42:15 +0000
Is there a way to make the volume pulling/stacking bars to...
View Count: 857
[2020-06-08 12:24:11] |
User123891 - Posts: 20 |
...be wider. It is the length of the pulling and stacking bars that I am interested in. I want to make the bars longer or even the column bigger. Thanks |
[2020-06-08 17:58:11] |
Yes, you can make them "wider" by increasing the size of the column. Refer to the information here for how to widen a column: Global Trade Settings Windows: Chart/Trade DOM Column Widths and Headers (Trade >> Customize Chart/Trade DOM Columns) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-08 18:19:35] |
Thank you. That was remarkably easy and helpful
