Date/Time: Fri, 07 Feb 2025 16:45:05 +0000
New bar new week
View Count: 583
[2020-06-08 11:47:27] |
User719310 - Posts: 23 |
Hi is it possible to treat each week as a session and draw a new bar on the start of each new week? Thanks |
[2020-06-08 19:01:50] |
What is the timeframe/ bar period setting of the chart bars?
[2020-06-08 19:27:34] |
I use renko bars. I realise that I can set days to load to 1 on a monday, but was wondering if there was a way to treat 1 week as 1 session so I can display more weeks going back on the chart.
[2020-06-09 06:24:17] |
The only option you can use is this which applies to days: Chart Settings: New Bar at Session Start (Chart >> Chart Settings >> Session Times >> Intraday Chart Session Times menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
