Date/Time: Fri, 07 Feb 2025 16:46:19 +0000
[Programming Help] - Indicator will not work on JY Futures
View Count: 816
[2020-06-08 11:11:35]
MikeVon - Posts: 20
I have a self programmed indicator which will load on all futures in the identical chartbook when I cycle through them in my symbol list(40+ Futures). It does not however load on the JY6 futures chart. Another indicator I programmed works fine on all Symbols including the JY6 Futures.
I've been looking for a solution but haven't been able to find one and would appreciate some help if you have any ideas.
Thanks.
