Date/Time: Fri, 07 Feb 2025 15:08:47 +0000
Errors on the DEPTH of the DOM whatever the mode of replays for all CME, CBOT, EUREX
View Count: 727
[2020-06-07 20:29:04]
User210074 - Posts: 63
In replay mode the DEPTH of the DOM is false.
I tested all the replay modes.
Same observation on all CME, EUREX, ...
I tested all the stable or PreRelaese versions.
I put screenshots on the release 2118 version
This version makes less error but the problem is still there.
Impossible to replay the dom.
Sorry I put several messages because we can only put a maximum of 3 PNG captures per message
image1.png / V - Attached On 2020-06-07 20:28:03 UTC - Size: 126.52 KB - 235 views
image2.PNG / V - Attached On 2020-06-07 20:28:13 UTC - Size: 123.64 KB - 222 views
image3.PNG / V - Attached On 2020-06-07 20:28:20 UTC - Size: 121.35 KB - 226 views
[2020-06-07 20:29:59]
other pictures
image4.PNG / V - Attached On 2020-06-07 20:29:27 UTC - Size: 120.38 KB - 244 views
image5.PNG / V - Attached On 2020-06-07 20:29:35 UTC - Size: 138.07 KB - 233 views
image6.PNG / V - Attached On 2020-06-07 20:29:45 UTC - Size: 177.36 KB - 239 views
[2020-06-07 20:31:32]
other pictures
image7.PNG / V - Attached On 2020-06-07 20:30:55 UTC - Size: 184.61 KB - 220 views
image8.PNG / V - Attached On 2020-06-07 20:31:02 UTC - Size: 120.45 KB - 224 views
image9.PNG / V - Attached On 2020-06-07 20:31:10 UTC - Size: 132 KB - 223 views
[2020-06-07 20:32:27]
other pictures
image10.PNG / V - Attached On 2020-06-07 20:31:59 UTC - Size: 121.77 KB - 227 views
image11.PNG / V - Attached On 2020-06-07 20:32:06 UTC - Size: 116.08 KB - 221 views
image12.PNG / V - Attached On 2020-06-07 20:32:17 UTC - Size: 128.13 KB - 213 views
[2020-06-07 20:33:48]
other pictures
image13.PNG / V - Attached On 2020-06-07 20:33:26 UTC - Size: 128.82 KB - 230 views
image14.PNG / V - Attached On 2020-06-07 20:33:34 UTC - Size: 124.03 KB - 227 views
[2020-06-07 20:35:09]
other pitures
image15.PNG / V - Attached On 2020-06-07 20:34:30 UTC - Size: 122.41 KB - 215 views
image16.PNG / V - Attached On 2020-06-07 20:34:41 UTC - Size: 125.41 KB - 228 views
image17.PNG / V - Attached On 2020-06-07 20:34:49 UTC - Size: 102.37 KB - 217 views
[2020-06-07 21:44:38]
You should not have made so many posts, we do not need to see all of these and they are all ignored. You are using an unsupported data feed and we are declining support here.
You need to switch to this service:
Sierra Chart / Trading Technologies Futures Order Routing Service
We can help you with this.
Date Time Of Last Edit: 2020-06-07 21:44:51
