Date/Time: Fri, 14 Mar 2025 13:58:12 +0000
Cumulative Delta time period reset
View Count: 1857
[2020-06-07 19:18:47] |
User457460 - Posts: 10 |
Hi folks Just wondering if it is possible to reset the cumulative delta to zero at the start of a new time period for anything higher than a day? Photo attached of where in the settings the day reset is possible to change, I have played around with the other option with no luck. Your feedback would be much appreciated. Many thanks! |
[2020-06-08 00:58:54] |
Ackin - Posts: 1865 |
Hi, How many days do you need? In the range of days, months, years?
Date Time Of Last Edit: 2020-06-08 01:04:17
[2020-06-08 02:06:10] |
The basic way to accomplish this is to set the Reset At Start of Trading Day Input to No and set the starting Date of the chart to where you want to begin the calculation at: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#UseDateRangeFromTo Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-08 02:06:58
[2020-06-08 09:40:34] |
Hi guys Many thanks for your input. I would like to get the cumulative delta to reset to zero every week/month/quarter/year. If I start it from a certain date I cannot get it to finish and reset at the start of a new time period on the higher time frames it’s just continuous. |
[2020-06-08 10:06:48] |
I thought so.... I would deal with days and weeks differently than quarters and years. Days can be counted cumulatively, but it would be unnecessary to overload the algorithm by counting the whole year .... there I would choose the path to the inserted date, from when to count again ... If you want it .... and it will not be solved by SCH Support, write me an e-mail with details and I will create it as needed (free as a study). contact link: https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free |
[2020-06-08 19:29:14] |
Oh fantastic I will send you an email - thank you!
[2022-06-25 13:16:59] |
MZTECH - Posts: 29 |
Thanks for the thread. I have done a lot of research and I cannot figure out how to solve the problem I am having with my order flow chart. In the Chart Settings: Use Date Range >> From / To (Chart >> Chart Settings >> Data Limiting menu) I do not see the option to select whether the data resets or not. I have tried to login to get a message to you regarding setting my cumulative delta on UVXY to work on past 100 days instead of resetting at 1700 and 0300 every day. but for some reason Sierra does not allow me to login to the forum. I registered though. mikezilai mikezilai@gmail.com |
