Date/Time: Mon, 21 Sep 2026 15:14:39 +0000
[Programming Help] - Notification between studies
View Count: 890
[2020-06-07 09:55:27]
backinblack - Posts: 43
Hi
I have 2 custom studies, S1, S2. Currently, S1 does some calculations and draws an alert on the chart. I am looking to use this alert for S2 now. As in whenever there is a signal on S1, S2 should be notified of it.
One way I think I can do it is store the indexes of alerts in S1 in a subgraph. Then use a persistent variable in S2 to point to the last updated index in the said subgraph in S1. That way, if S1 updates its subgraph, S2 can compare it against its persistent variable and detect that there is a new signal generated in S1.
Is there another/better way to do it that i dont know about?
-J
[2020-06-07 10:04:21]
Ackin - Posts: 1865
Another way ("better" I don't know)- get result from Summary window....
[2020-06-07 10:22:33]
Thanks for the reply. I am looking to do it in ACSIL (Sorry should have mentioned in my original post)
[2020-06-07 10:51:48]
Ackin - Posts: 1865
I also wrote about ACSIL
Date Time Of Last Edit: 2020-06-07 10:55:30
[2020-06-07 10:53:33]
Ackin - Posts: 1865
Look:
ACSIL Interface Members - Functions: sc.GetStudySummaryCellAsDouble()
ACSIL Interface Members - Functions: sc.GetStudySummaryCellAsString()
Date Time Of Last Edit: 2020-06-07 10:56:27
[2020-06-07 20:13:19]
ForgivingComputers.com - Posts: 1238
You can get and set a persistent variable from another chart study: ACSIL Interface Members - Functions: sc.GetPersistentFloatFromChartStudy()
