Date/Time: Fri, 07 Feb 2025 15:12:23 +0000
woodies Indicator
View Count: 859
[2020-06-07 05:25:58] |
User858036 - Posts: 4 |
I am learing futures trading with my mentor I can not find Woodie indictor on the softawre trial attacing picture for the required indicator Best regards yossie Date Time Of Last Edit: 2020-06-08 00:58:17
woodies indicator.jpg / V - Attached On 2020-06-07 05:25:12 UTC - Size: 32.88 KB - 357 views |
[2020-06-07 07:52:18] |
Ackin - Posts: 1865 |
Woodies CCI Trend Woodies CCI Trend Sierrachart / Menu / Analysis / Studies ... you find it in the list |
[2020-06-08 00:58:45] |
This is something we are not able to help with.
