Date/Time: Fri, 07 Feb 2025 15:06:15 +0000
transact
View Count: 609
[2020-06-07 00:56:08] |
User143551 - Posts: 102 |
you sent the message to me ,we do not understand why you insist on using transact when we have better way ,so who are you saying to use ,all I need is a good broker not a charting system
[2020-06-07 00:57:15] |
Any broker that supports the Sierra Chart Order Routing Service: Sierra Chart / Trading Technologies Futures Order Routing Service The supported brokers are listed in the Setup Instructions at step 2 on that page. And the basis of our recommendation is that you do not have to go through a manual verification related to authorizing the CME data each month, which you struggle with every month and you always request our help with each month and have numerous questions about. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-07 00:57:56
