Date/Time: Mon, 25 Nov 2024 08:00:44 +0000
trading from chart
View Count: 1115
[2014-01-24 23:23:50]
dominikos - Posts: 106
gearing up to go live with sierra chart, hence finding areas I'm not completely comfortable with. When trading from a chart,
a) is there a way to ensure that chart does not overlap DOM graph? even if I move it, the chart will eventually move to the right and cover the bars.
b) is there a way to setup order templates (using attached orders) to be automatically executed from trading chart DOM?
thanks
[2014-01-25 00:59:01]
1. Yes by adding fill space to the right side of the chart and locking it:
http://www.sierrachart.com/index.php?l=doc/doc_WorkingWithCharts.html#ScrollingTheChart
2. Yes, by saving and selecting a Trade Window configuration:
http://www.sierrachart.com/index.php?l=doc/doc_TradeWindow.html#MenuButton
Date Time Of Last Edit: 2014-01-25 00:59:48
