Date/Time: Fri, 07 Feb 2025 15:17:14 +0000
Updating study for new version
View Count: 758
[2020-06-06 21:55:35] |
anouar6869 - Posts: 13 |
Hi support, I need help to update this part of code: int& PivotIndex = sc.PersistVars->Integers[npi++]; int& NextLineNumber = sc.PersistVars->Integers[npi++]; int& NextLineIndex = sc.PersistVars->Integers[npi++]; // Clear persistent data on (re)load if (sc.UpdateStartIndex == 0) { memset(sc.PersistVars, 0, sizeof(s_PersistentVariables)); } thanks |
[2020-06-07 01:40:50] |
Refer to this thread: Notice: Study Exceptions in New Versions and Code Efficiency And to this ACSIL function: sc.ClearAllPersistentData() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-07 04:33:22] |
It works only if I put sc.ClearAllPersistentData() right after the default block, is that correct? It works fine.. only to be sure. Thanks ///////////////////////////////////// if (sc.SetDefaults) { ............. return; } // Clear persistent data on (re)load if (sc.UpdateStartIndex == 0 ) { sc.ClearAllPersistentData(); ) // Main processing int npi = 0; int& PivotIndex = sc.GetPersistentIntFast(npi++); int& NextLineNumber = sc.GetPersistentIntFast(npi++); int& NextLineIndex = sc.GetPersistentIntFast(npi++); |
[2020-06-08 01:37:37] |
It is correct now the way you have it, but we do realize there is a safety problem with sc.ClearAllPersistentData regarding the fast persistent variables. This will be solved in the next release. When this is solved, you can use sc.ClearAllPersistentData anywhere.
