Date/Time: Fri, 07 Feb 2025 14:42:34 +0000
UDP error
View Count: 676
[2020-06-06 21:34:12]
User316362 - Posts: 210
In my second sierra instance, I'm getting the following error in my message log
"UDPListener (1780). Port 22903 | Error binding to UDP port: 22903. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted."
Is this a problem I should be worried about?
V 2115
Also is there a way to close the sub-instance (2) by closing the main instance of sierra chart?
Date Time Of Last Edit: 2020-06-06 21:39:49
[2020-06-07 00:53:03]
Set this setting to 0:
https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#UDPPort
The answer is no to your second question.
