Date/Time: Fri, 07 Feb 2025 14:52:30 +0000
How do I do a TICK chart with Sierra?
View Count: 2411
[2020-06-06 14:20:00] |
User685606 - Posts: 29 |
I've been trying to play around with adding a tick chart (I normally use TIME based charts - 1 min, 5 min, etc). I must be doing something wrong with tick charts because it just doesn't look right (the bars are HUGE). How do I do a 500 tick chart?
[2020-06-06 15:05:45] |
Sawtooth - Posts: 4173 |
In Sierra they are more accurately called 'Number of Trades per Bar'. Chart Settings: Intraday Chart Bar Period >> Bar Period Type >> Number of Trades Per Bar (Chart >> Chart Settings menu) |
[2020-06-07 01:17:00] |
Yes the answer given at Post #2 is the setting that you need to use.
