Date/Time: Fri, 07 Feb 2025 15:15:30 +0000
Historical daily bar chart data missing
View Count: 808
[2020-06-06 02:56:09] |
User663121 - Posts: 7 |
Dear Sir. I am not able to get the access to any historical daily bar charts since the 29th of May,I was try to re-downlaod those missing data via “Edit“ function, but the problems are not resolved, I am with Rithmic and switching to SC data routing services at this stage.please help. Thanks Date Time Of Last Edit: 2020-06-06 03:03:45
[2020-06-07 13:20:27] |
This problem does relate to using Rithmic. It will be resolved when changing to the Sierra Chart Order Routing Service: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-07 13:20:36
