Date/Time: Fri, 07 Feb 2025 15:08:04 +0000
trial account
View Count: 490
[2020-06-05 22:17:51]
serg777 - Posts: 2
hi.
Could you extend the trial version of Sierra. I was going to try to study your product many times, but there was no time for it. I would like to try again. thanks in advance
[2020-06-06 01:11:41]
Your account has been activated and the usage time extended if necessary.
If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu.
After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit".
