Date/Time: Mon, 25 Nov 2024 07:28:51 +0000
Spreadsheet System for Trading
View Count: 1151
[2014-01-24 22:30:03] |
rick e - Posts: 51 |
Would you consider in some future version of "Spreadsheet System for Trading" that Bid and Ask columns be added to this fine study since an open long would be offset on the BID and a short on the ASK and neither on the LAST most likely, thus allowing one to know their TRUE open position exposure. Thanks for your consideration.
[2014-01-25 00:53:55] |
If you are referring to the latest Bid and Ask prices those are available in the Spreadsheet already. Refer to this particular section: http://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php#CurrentQuoteValues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-25 00:55:06
