Date/Time: Fri, 07 Feb 2025 16:55:01 +0000
Exclude certain elements from the function "Copying Chart Drawings from Other Charts" possible ?
View Count: 840
[2020-06-05 21:32:57]
User355493 - Posts: 27
Hello Siera-Chart Team,
Is it possible to exclude certain elements from the function "Copying Chart Drawings from Other Charts" ?
Background: I don't want to copy text, the rest of the elements (retangle, lines, etc) should be copied.
I would have to write different text in different chart windows without copying them among themselves.
Thank you very much for a Reply.
Date Time Of Last Edit: 2020-06-05 22:15:37
[2020-06-05 23:41:05]
You can control this per individual Chart Drawing. Allow Copy to Other Charts can be added to the Chart Drawing shortcut menu:
Chart Drawing Tools: Customizing Chart Drawing Shortcut Menu
[2020-06-06 10:03:16]
Cannot find the function "Allow Copy to Other Charts" to add this to "Chart drawing shourtcut menu". (see attachment). There´s no function here which begins with "Allow….."
In which categegory should this function be found ? I´m using Version 2115.
Date Time Of Last Edit: 2020-06-06 10:03:56
imagesc.PNG / V - Attached On 2020-06-06 09:55:49 UTC - Size: 31.53 KB - 267 views
[2020-06-08 03:11:49]
You need to use Global Settings >> Customize Chart Drawing Menu.
