Date/Time: Fri, 07 Feb 2025 15:07:55 +0000
Customized spread
View Count: 557
[2020-06-05 15:31:08] |
User120056 - Posts: 1 |
Can I customize a spread (not the exchange ones) with selected legs on Sierra Chart and place a trade of the spread? For example, I pick HSI and ES as the legs and customize this as a spread?
[2020-06-07 13:17:20] |
Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done.
