Date/Time: Fri, 07 Feb 2025 17:03:08 +0000
Intraday Charts Not showing Time
View Count: 907
[2020-06-05 13:44:23]
CMG - Posts: 179
Intraday charts are not showing times at any time frame. Every time mark shows as 0:00.
Message log shows mesage:
ESM20 1 Min #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 0-00-00 00:00:00. Next Bar Date Time: 0-00-00 00:00:00. Filename: ESM20.scid | 2020-06-05 09:28:33.577
Thank You
[2020-06-05 14:43:57]
CMG - Posts: 179
Problem is only for Futures charts/data. Equities chart print times (x axis) correctly. ES prices shows but no time data (all times are 0:00.) No data at all for YM.
Thank You
[2020-06-05 18:08:26]
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
[2020-06-05 19:34:23]
CMG - Posts: 179
Charts working now, however, no real time data (intraday not updating) when using SC data services. I performed the usual connect to trading service and switch back to SC data to no avail. If I connect to my trading service and use their symbol charts do update.
Thank You
[2020-06-08 02:55:59]
You also need to translate the symbols:
Edit Menu: Edit >> Translate Symbols To Current Service
