Date/Time: Thu, 06 Mar 2025 14:11:25 +0000
VbP study text color
View Count: 1212
[2020-06-05 12:55:25] |
User98657 - Posts: 341 |
I'm only showing the total volume at the top of my Volume Profile (VbP). Display Data in Chart VAlues Window (In:93) - Yes Show Chart Values on Profile (In:5) - Do Not Show Chart Values on Profile Char Values Position on Profile (In:6) - Top of the Graph Text Font Size (In:110) - 10 The color of the text is set to light gray and I cannot find a setting that affects that font. I've done a google search and tried all the solutions i could find in that search. Volume Numbers Text Color and Size is not it. I've also checked all my font settings in Chart>Graphics Settings and the fonts tab - all the fonts seem to be set to black, butt this font is still gray. Appreciate any help. |
[2020-06-05 18:39:47] |
So we can understand this better, post an image of that chart: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-05 18:41:21
[2020-06-08 15:17:03] |
http://www.sierrachart.com/image.php?Image=1591629397492.png
[2020-06-08 15:31:10] |
Ackin - Posts: 1865 |
User98657 ) Volume Profile (VbP) - in the setting of study look in the tab "Subgraphs" ... Text Color Size SG7 .... |
[2022-02-01 15:29:29] |
pete3m - Posts: 15 |
Raising this from the dead - I can change font size and font color OK, but I cannot get the colors to change based on +/- Is there another setting overriding this or is this feature not available? See RED arrow to NEG imbalance which is still 'blue', although I have changed SG7 settings in VbP to +/-, blue/pink respectively. https://www.sierrachart.com/image.php?Image=1643729266293.png Thank you! Date Time Of Last Edit: 2022-02-01 15:30:03
[2022-02-01 16:41:21] |
John - SC Support - Posts: 38425 |
Coloring of that text for the VbP is not affected by the "Based On" setting.
[2022-02-01 18:31:31] |
So as I understand this coloring must remain static, correct? Thank you for the response.
[2022-02-01 22:12:27] |
You can change the color of the text, but it will not change based on the values. It is just the one color that you select.
