Date/Time: Fri, 07 Feb 2025 17:22:40 +0000
Study: Daily OHLC
View Count: 837
[2020-06-05 09:23:40] |
cfuture - Posts: 68 |
I am looking for a study similar which would allow the chart to show the OHLC for each individual day for a specified number of bars or time period. Eg show OHLC for each individual day for the last 10 days. I thought Period OHLC-Variable Period might help, but was also a strike out. Is there something else available or a solution other than having to have numerous replications of this study?
Date Time Of Last Edit: 2020-06-05 09:33:30
[2020-06-05 20:22:30] |
Based upon the what we understand you want, you would want to use Period OHLC-Variable Period. So we must not be understanding exactly what you need in complete detail.
[2020-06-06 21:16:30] |
Currently, I have 30 instances of the Daily OHLC study in order to see the OHLC for the last 30 days. It would be quite more efficient to have just one study performing the same. Such a new study would incorporate the ability to draw the OHLC for each individual day, week, or month over a specified number of bars. Eg draw the OHLC for each individual day for the last ten days.
Date Time Of Last Edit: 2020-06-07 20:29:22
[2020-06-08 02:27:25] |
This is already supported what you want to do. Not sure why you have 30 instances of that study. Check the Number of Days to Calculate Input with that study and make sure it is set to at least 30. Also have a look at this study: Previous/Period OHLC-Variable Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-08 13:57:51] |
according to your last message, then I must be doing something wrong trying to draw each individual OHLC for the last 30 days. I have made a snippet of the settings also uploaded an image of the chart, but it fails to show each individual OHLC for the last 30 days according to your last message's advice, but instead only shows the 30th day OHLC. http://www.sierrachart.com/image.php?Image=1591624060610.png |
[2020-06-08 14:07:37] |
Ackin - Posts: 1865 |
Hi, I created for this similar study if you want try it: Study: Universal Daily H/L from study .....(chart)... H or L from days range contact link: https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free |
[2020-06-08 17:57:02] |
Set the Reference Days Back to 0. Refer to the information for that Input here: Daily OHLC: Inputs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
