Date/Time: Fri, 07 Feb 2025 14:05:40 +0000
DAX CFD & Market Profile
View Count: 723
[2020-06-05 04:52:08] |
Marcel Hagin - Posts: 10 |
Hello, i have a problem. The software runs very well and all markets work very well. I am using your CFD data. But once I select the Dax, the Market Profile Chart is so slow that I can't work with it. Forex and commodities S&P are no problem but the Dax. Is there anything that can be optimized in the settings? Many greetings |
[2020-06-05 05:59:31] |
Are you referring to a TPO Profile Chart? If so, increase the value for this Input setting: Time Price Opportunity (TPO) Profile Charts: Letter/Block Price Increment in Ticks Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
