Date/Time: Fri, 07 Feb 2025 13:58:33 +0000
Using Denali & SC Exchange Data Feed simultaneously
View Count: 726
[2020-06-04 20:26:23]
jwick - Posts: 142
I currently have a Denali subscription for CME data.
I just activated a first connection to Sierra Chart Real-Time and Historical Exchange Data Feed and subscribed to US Equities Data.
My Data / Trade service settings are set to Interactive Brokers with "Allow Support for Sierra Chart Data Feeds" enabled. This successfully connects me to the Denali exchange when pulling in data for CME futures. However, when I attempt to load data for a stock, it appears to be using Interactive Brokers (I see this in my mesage log):
"Interactive Brokers | Starting real-time market data updates for: MSFT. ID: 16 | 2020-06-04 16:21:07.756
Interactive Brokers | Requesting security definition data for: MSFT. ID: 16 | 2020-06-04 16:21:07.756"
[2020-06-04 23:35:27]
Do you see an [M] indicator on the title bar of the stock chart?
See if that resolves the problem.
[2020-06-05 00:10:14]
jwick - Posts: 142
I don't see an [M] (eg: https://i.imgur.com/bg8ULTQ.png). I followed the symbol settings update steps on my main instance as well as the sub-instance. No change. I also tried loading the chart directly in the main instance. No [M].
[2020-06-05 00:12:11]
Reconnect to the data feed:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2020-06-05 00:24:44]
jwick - Posts: 142
Oops my bad. It looks like in my main instance, at first the symbol doesn't have an [M] but after a little time it does get properly tagged with [M]. I also read Chart Data and Chart Data Files: The Meaning of the [M] Designation after a Symbol which indicated that sub-instances won't get tagged with [M] since it's always using a primary data source (the main instance) so that explains that.
I also cleared my logs as you suggested and it appears everything is working as it should. Eg:
"Enabled for exchange: U.S. Equities (NYSE, NASDAQ, AMEX, BATS) | 2020-06-04 20:16:53.902
Enabled for exchange: BATS (NYSE, NASDAQ) | 2020-06-04 20:16:53.902"
"Mapping TSLA to TSLA. Service code: equities.us | 2020-06-04 20:17:43.102"
Thanks for your help!
