Date/Time: Fri, 07 Feb 2025 16:56:47 +0000
Attach Target order to existing position
View Count: 1207
[2020-06-04 18:27:39] |
User189132 - Posts: 63 |
Hi, I have a position on GCQ20 in simulated trading. The original order was at 1705 (that got filled) with Stop Limit Order 1690. I tried to attach target order to the position. I did Send Attach Orders by Price with reference Price being 1751. The order that was created was duplicate of my stop order of 1690. What am I missing? Thank you. |
[2020-06-04 23:48:52] |
What exactly were the Attached Orders that you sent. If that included a stop then there would be another stop.
[2020-06-05 12:49:07] |
I did not realize that settings in Target tab are driving the order. I "attached" the target order today. However when my stop limit loss was triggered and executed today the Target Order was not cancelled. Why? All in simulated account. What am I missing? Thank you |
[2020-06-05 15:13:45] |
To make things simpler, Please provide step by step instructions how to attach a Target Limit Order to an existing position.
[2020-06-05 18:14:27] |
Since this is just a single order, you would just simply submit the Limit order as an individual order. Refer to: Chart Trading and the Chart DOM: Entering Orders From the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-07 11:48:15] |
This will NOT work, because I need the system to cancel the Stop Loss order when newly attached Target order is executed or other way around, when Stop Loss is executed I need newly attached Target order to be cancelled.
[2020-06-08 03:09:11] |
Therefore, refer to: Attached Orders: Changing Attached Orders Configuration After Parent Order Has Filled Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
