Date/Time: Fri, 07 Feb 2025 14:06:50 +0000
Trade station connectivity and woodie indicator
View Count: 684
[2020-06-04 16:05:27] |
User858036 - Posts: 4 |
Hello to the supporter I am a new cammer to Sierra softwrae recomended by my trading mentor 1. is there a good software tutoiral recomanded ? 2. I would like to prectic with woodie indicator and it looks like there is missing data no CCI lines 3. Do the software as a Trade statin connectivity so i can trade thrue my T.S brokrage ? 4. English is not my mothure tung languch - do you have a speller i can use to reduce my typing errors ? THank you I will apprciate quick answers |
[2020-06-04 23:42:29] |
1. Refer to: Getting Started, Opening Charts and Basic Trading 2. We do not provide support for this. You need to use the supported services here: Supported Data and Trading Services 3. No. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-04 23:42:54
