Date/Time: Fri, 07 Feb 2025 16:58:16 +0000
SP500 index data with AMP
View Count: 1424
[2020-06-04 14:07:52] |
User575620 - Posts: 4 |
I am a AMP client currently connecting with CQG WebAPI. I only trade the minis and i also use simulated trade functions. Is there a way to get SP500 index real time data?
[2020-06-04 23:58:06] |
Refer to this section here about this: Real-Time Exchange Data Feeds Available From Sierra Chart: Cash Indexes If you want to use the Sierra Chart Denali Exchange data feed for futures data, then refer to the information here: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-04 23:59:04
[2020-06-05 22:20:05] |
Based on the link you provided I found the following Indexes: SPX500 | S&P 500 Index - the closing price for today 6/6/2020 was showing at 3188.98 but it should have been 3193.93 $INX | S&P 500 Index - S&P Indices - gives the message "Symbol is unknown" $SPX | S&P 500 Index - CBOE Indices - gives the message "Symbol is unknown" X.US.SPC5 | SP 500 Index - gives the message "Symbol is unknown" Would you kindly explain to me what the differences are and how much they cost? Since I am connecting with CQG, should I be able to receive X.US.SPC5 since it is under the category of "CQG Indexes" Thank you |
[2020-06-08 02:55:00] |
We do not provide technical help for CQG market data. $INX | S&P 500 Index - S&P Indices
This is the right symbol but to access the real-time data you do have to subscribe to it:- gives the message "Symbol is unknown" Real-Time Exchange Data Feeds Available From Sierra Chart: Cash Indexes The instructions also explain how to access historical data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
