Date/Time: Mon, 24 Feb 2025 07:34:59 +0000
Connection Error
View Count: 3435
[2020-06-04 11:35:34]
John R D - Posts: 25
Hi I'm getting a connection error. I have a data feed thru Rithmic but I'm
not able to get a connection. Pleas let me know the problem. Thanks.
John
[2020-06-04 13:42:00]
John - SC Support - Posts: 38116
Refer to the information here:
Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward
[2020-06-04 15:32:41]
Hi I followed that thread now Im getting this message.
Connection error message from service. Rithmic Trading Error running DTC server program/Sierra chartv2/Rim/DTCBrigdge.exe.
Rithmic bridge needs installing. To obtain bridge files. go to. It sends me to the same thread that didn't work.
Do you have any other suggestions?
[2020-06-04 15:48:55]
Did you do the following:
1. Use the .zip file in that thread to copy the files to your system
2. Create a file named "Rim" under the top level Sierra Chart directory if it did not already exist.
2. Open the .zip and copy the files from it into the folder named "Rim" that you either just created or was already there.
3. Select the option to Replace the files that were already in that directory
[2020-06-04 22:34:12]
Have you been able to look at my attachments? I still have not been able to log on
to Sierra chart.
[2020-06-04 22:57:15]
We apologize for the delay. We actually need to see the Message Log.
Select File >> Connect to Data Feed.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2020-06-04 23:22:16]
Software version: 2115 32-bit | 2020-06-04 19:21:50.401
Primary Thread ID: 10272 | 2020-06-04 19:21:50.401
Usage end date: 2020-06-19 | 2020-06-04 19:21:50.401
Enabled for: Advanced Features 2. | 2020-06-04 19:21:50.401
Enabled for: Sierra Chart Historical Data Service. | 2020-06-04 19:21:50.401
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-06-04 19:21:50.401
Allow Support for Sierra Chart Data Feeds is disabled. | 2020-06-04 19:21:50.401
Current selected Data/Trading service: Rithmic Trading | 2020-06-04 19:21:50.401
Custom symbol settings values: disabled | 2020-06-04 19:21:50.401
Chart Update Interval: 500 | 2020-06-04 19:21:50.401
Intraday Data Storage Time Unit: 0 | 2020-06-04 19:21:50.401
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-06-04 19:21:50.401
2020-06-04 19:21:50 Local computer time | 2020-06-04 19:21:50.401
2020-06-04 23:21:50 Local computer time in UTC | 2020-06-04 19:21:50.401
2020-06-04 19:21:50 Local computer time in SC Time Zone | 2020-06-04 19:21:50.401
2020-06-04 23:21:08 Server time in UTC | 2020-06-04 19:21:50.401
Local computer UTC time and Server UTC time difference: 1 seconds. | 2020-06-04 19:21:50.401
Program path: C:\SierraChartV2\ | 2020-06-04 19:21:50.401
Data Files path: C:\SierraChartV2\Data\ | 2020-06-04 19:21:50.401
OS Version Number: 10.0 | 2020-06-04 19:21:50.401
Locale Setting: C | 2020-06-04 19:21:50.401
Allowed protected custom studies: GomOrderFlowPro | 2020-06-04 19:21:50.401
Rithmic Trading | Port for executable: 39961 | 2020-06-04 19:21:51.667
Listening socket (1528). Port 39961 | Closed. | 2020-06-04 19:21:51.667
Rithmic Trading | Starting server: C:\SierraChartV2\Rim\DTCBridge.exe | 2020-06-04 19:21:51.668
Error creating process C:\SierraChartV2\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2020-06-04 19:21:51.669 *
Rithmic Trading | Error running DTC server program C:\SierraChartV2\Rim\DTCBridge.exe. Rithmic bridge needs installing. To obtain the bridge files, go to: Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward | 2020-06-04 19:21:51.669 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-04 19:21:51.669
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-04 19:21:51.669
DTC Client socket (0) | CloseSocket call. | 2020-06-04 19:21:51.676
Rithmic Trading | Disconnected. | 2020-06-04 19:21:51.676
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-04 19:21:51.676
Rithmic Trading | Port for executable: 39962 | 2020-06-04 19:21:53.678
Listening socket (732). Port 39962 | Closed. | 2020-06-04 19:21:53.678
Rithmic Trading | Starting server: C:\SierraChartV2\Rim\DTCBridge.exe | 2020-06-04 19:21:53.679
Error creating process C:\SierraChartV2\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2020-06-04 19:21:53.680 *
Rithmic Trading | Error running DTC server program C:\SierraChartV2\Rim\DTCBridge.exe. Rithmic bridge needs installing. To obtain the bridge files, go to: Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward | 2020-06-04 19:21:53.680 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-04 19:21:53.680
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-04 19:21:53.680
DTC Client socket (0) | CloseSocket call. | 2020-06-04 19:21:53.698
Rithmic Trading | Disconnected. | 2020-06-04 19:21:53.698
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-04 19:21:53.698
[2020-06-05 11:06:40]
Hi any idea what is going on?
[2020-06-05 17:40:20]
Hi again can you help me with this situation? Thanks.
John
[2020-06-05 17:57:44]
Yes we will need to have a remote assistance call to help you install the files. We have been extremely busy and we just are not able to get to this quickly. We also have discontinued support for Rithmic. Support for Rithmic has been discontinued for more than six months now.
Who is your futures broker?
Date Time Of Last Edit: 2020-06-05 18:00:17
[2020-06-05 19:42:54]
It's thru Earn 2 Trade. I'm not sure who there broker is. Trust me I wish these companies didn't use Rithmic.
I understand you are busy. Thanks for getting back to me.
When would we be able have a remote assistance call?
[2020-06-08 14:41:15]
Are we able to have a call today? Thanks. John
[2020-06-08 16:50:31]
We just tried calling but could not get connected. Please ensure that the phone number associated with your account is correct. You can update it here:
https://www.sierrachart.com/UserControlPanel.php?page=ManageAccountInfo
You may need to login to the Sierra Chart website if you are not already logged in.
Let us know if there is a specific time that is best to call, including time zone.
[2020-06-08 17:54:36]
I just updated the phone number. Thanks
[2020-06-08 18:37:26]
Called and installed files for customer. Customer is working fine now.
[2020-06-08 20:13:22]
Thanks for getting me set up. I noticed there is no Data at Bid or Ask on the Dom. Also my hotkeys don't work with dom or chart trading. I can only click on the Dom or the trade window. Does the data have to do with the rule changes? Hot key stuff is bizarre. Any idea what's going on?
[2020-06-09 02:44:51]
For everything relating to market depth data, refer to:
File Menu: Open Market Depth Window (File)
As to the "hotkeys", the most likely situation is simply that you do not have the option for Trade >> Trading Keyboard Shortcuts Enabled. Refer to the information here:
Trade Menu: Trading Keyboard Shortcuts Enabled (Trade menu)
Full relevant documentation:
Basic Trading and the Trade Window: Trading from the Keyboard, Pointer, and Control Bar
Date Time Of Last Edit: 2020-06-09 02:45:49
[2020-06-10 18:44:27]
Thanks for your feedback. My data is fine now however all my hotkeys were erased (order entry/drawing tools). So I'm
re mapping them now. Any clue what could of happened here.
[2020-06-11 04:50:51]
No we do not know why there would be a problem but you can use a backup configuration file:
Resetting Sierra Chart to a Default State / Restoring Backup Global Configuration File: Restoring Backup Global Configuration File
Date Time Of Last Edit: 2020-06-11 04:53:04
[2021-03-07 10:08:07]
User92r - Posts: 1
Dear fellow,
seemingly I have a same problems. Could you please help me:
Listening socket (0). Port 50372 | Closed. | 2021-03-07 09:57:45.953
Rithmic Trading | Starting server: C:\SierraChart0\Rim\DTCBridge.exe | 2021-03-07 09:57:45.953
Created process C:\SierraChart0\Rim\DTCBridge.exe. Current folder: C:\SierraChart0\Rim | 2021-03-07 09:57:45.953
Rithmic Trading | Bridge process is not running! | 2021-03-07 09:57:47.958
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50372 | 2021-03-07 09:57:47.958
DTC Client socket (3) | Creating socket. | 2021-03-07 09:57:47.958
DTC Client socket (3) | New receive buffer size: 5242880 | 2021-03-07 09:57:47.958
DTC Client socket (3) | Connecting to IP: 127.0.0.1. | 2021-03-07 09:57:47.958
DTC Client socket (3) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-03-07 09:57:48.973 *
DTC Client socket (3) | CloseSocket call. | 2021-03-07 09:57:48.973
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-03-07 09:57:48.973
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-03-07 09:57:48.973
DTC Client socket (3) | Closed. | 2021-03-07 09:57:48.973
DTC Client socket (0) | CloseSocket call. | 2021-03-07 09:57:48.989
Rithmic Trading | Disconnected. | 2021-03-07 09:57:48.989
Thank you
[2021-03-08 10:07:02]
Sierra_Chart Engineering - Posts: 18541
At this time we are not providing technical support for Rithmic. You will need to use one of the other supported services:
Supported Data and Trading Services
