Date/Time: Fri, 07 Feb 2025 13:44:56 +0000
DOM
View Count: 573
[2020-06-04 08:30:40] |
User941978 - Posts: 8 |
Hello I have attached a screenshot Is there a setting so that the recent bid/ask are automatically deleted after a certain time? Thanks |
Screenshot_1png.png / V - Attached On 2020-06-04 08:30:12 UTC - Size: 10.32 KB - 209 views |
[2020-06-05 10:13:49] |
Refer to the documentation for those market data columns here: Global Trade Settings Windows: Recent Bid Volume - Left/Center/Right Aligned Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
