Date/Time: Fri, 07 Feb 2025 14:12:23 +0000
CPU falls asleep with SC running?
View Count: 544
[2020-06-03 23:35:49] |
Jjgu - Posts: 8 |
While SC is running with auto trade on do I have to change settings on my computer for it to not go to sleep? Thanks!
[2020-06-04 02:03:01] |
You have to change only operating system power related settings.
