Date/Time: Fri, 07 Feb 2025 13:48:37 +0000
Data Feed with Interactive Brokers
View Count: 825
[2020-06-03 20:30:31] |
User150600 - Posts: 4 |
Hello, I setup my SC and connected my data feed to my Interactive Brokers (TWS) platform. It seems to be running fine. Upon more Google search, it appears IB does not have tick data and therefore cannot support order flow or market depth related information. What is my alternative and cost to obtain a live futures data feed with market depth? Am I required to pay for both Denali data feed + CME exchange fees? Or just CME fees because I have a supported futures broker? Thanks. |
[2020-06-03 23:44:03] |
You need to pay for both the Denali Exchange Data Feed itself ($25.00 USD per month) and the appropriate exchange fees. If you are not considered a professional by the exchanges, then you will qualify for the lower priced Non-Professional CME exchange fees since you can connect to IB to validate your status. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
