Date/Time: Fri, 07 Feb 2025 15:17:46 +0000
[User Discussion] - Displaying more of a 1 sec chart
View Count: 863
[2020-06-03 20:01:33] |
User80541 - Posts: 13 |
I have a a few bond charts and a difference chart with the Difference Line of the Bonds on a different chart on a 1 sec timeframe (I can only see a few hours max). How can I squeeze the chart to show more duration in my window (since I want to fit a few of these windows on my monitor) and want to see a longer duration (not just last 2 or 3 hours) Worse is sometimes it only shows me an hour.. other times it shows me like 3 to 5 hours when I squeeze it max on the X axis I have looked through and tried several things still no luck Changing the timeframe of the Bar defeats the purpose |
[2020-06-08 00:42:57] |
Ackin - Posts: 1865 |
Just an idea: Try Overlay OHLC study (from the default list of studies) In the study settings in the "Subgraphs" tab, change the Displacement value to the screen width value. (for counting use the "Bar Numbering" study ... you'll see the bar numbers next to each other) Create as many regions as you want ... you'll have it as more monitors .. it's not a great solution but better than nothing;) |
