Date/Time: Sun, 04 Oct 2026 19:15:37 +0000
ACSIL dll for multiple charts/chartbooks
View Count: 906
[2020-06-03 15:40:10]
sugart - Posts: 25
Is it recommended to use the same dll file on multiple chartbooks simultaneously, or copies of the same dll with different names?
For example, an ACSIL strategy with the name strategy.dll.
Is it better to use the same file strategy.dll to trade multiple stocks on different charts/chartbooks simultaneously, or copies of it separately for each stock, i.e., strategycopy1.dll, strategycopy2.dll, etc?
Thank you.
[2020-06-03 15:59:48]
ForgivingComputers.com - Posts: 1239
Normally, the same DLL can be safely used on different charts and chartbooks, and even multiple times in the same study. Despite having the same names, they are usually independent and do not interfere with each other, just like the standard studies provided with Sierra Chart.
While it is possible to create custom studies that interfere with each other, is unlikely you will see any.
[2020-06-04 06:48:34]
It is perfectly fine to use a single DLL.
