Date/Time: Sun, 13 Sep 2026 19:26:10 +0000
Calculating averages
View Count: 1872
[2020-06-03 15:35:44]
user2837 - Posts: 76
Suppose I want to calculate the average volume of ES (continuous contract) 7:30 pm 10 minute candles over a specified period of time. Is there a scripting or programming framework to do such a thing?
[2020-06-03 16:02:26]
Let me modify my question. The easiest would be if I can get minute by minute data in csv format for a certain period of time. I can then write the program to find the averages in any language.
[2020-06-03 16:08:18]
Ackin - Posts: 1865
Try this:
Moving Average - Time Period
If you only want part of the day (I'm not sure what do you mean by "over a specified period of time.") a filter would have to be made in Spreadsheet or Acsil ...
Date Time Of Last Edit: 2020-06-03 16:27:19
[2020-06-03 16:31:10]
Thanks. I would like data really over months and if possible over years. With the data, I can compute averages any way I want to.
[2020-06-03 17:09:12]
This link seems to do it for downloading data: Exporting and Importing Intraday Data Files
[2020-06-03 17:55:17]
You can use the Moving Average-Simple study:
Moving Average - Simple
Also have a look at the Relative Volume study:
Relative Volume
