Date/Time: Sat, 12 Sep 2026 16:27:38 +0000
Rithmic data connexion
View Count: 812
| [2020-06-03 15:21:51] |
| User654150 - Posts: 1 |
Hello I can no longer connect to Sierra with rithmic, why? I have everything checked username password, firewall ... what is the instruction? Thank you in advance for your answer. Message Log: Rithmic Trading | Port for executable: 50787 | 2020-06-03 15:26:40.862 Listening socket (1728). Port 50787 | Closed. | 2020-06-03 15:26:40.862 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-06-03 15:26:40.863 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50787. Current folder: D:\SierraChart\Rim | 2020-06-03 15:26:40.868 Rithmic Trading | Bridge process is running. | 2020-06-03 15:26:42.876 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50787 | 2020-06-03 15:26:42.876 DTC Client socket (1) | Creating socket. | 2020-06-03 15:26:42.876 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-03 15:26:42.876 Rithmic Trading | Connected to server. | 2020-06-03 15:26:42.878 Rithmic Trading | Starting socket receive thread. | 2020-06-03 15:26:42.878 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-03 15:26:42.878 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-03 15:26:42.879 Rithmic Trading | Sending logon request message. | 2020-06-03 15:26:42.879 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-03 15:26:42.880 Rithmic Trading | Message from server: Logging is enabled. Log file: D:\SierraChart\Rim\Rithmic.log | 2020-06-03 15:26:42.882 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-03 15:26:42.882 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-03 15:26:43.942 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-03 15:26:44.509 Rithmic Trading | Received logon response. | 2020-06-03 15:26:44.510 Rithmic Trading | Server Name: DTC Bridge. | 2020-06-03 15:26:44.510 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-03 15:26:44.510 Rithmic Trading | Logon error received from server | 2020-06-03 15:26:44.510 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-03 15:26:44.510 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-03 15:26:44.510 DTC Client socket (1) | CloseSocket call. | 2020-06-03 15:26:44.531 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-03 15:26:44.531 Rithmic Trading | Disconnected. | 2020-06-03 15:26:44.531 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-03 15:26:44.531 Message: Service connection Error Connection error message from service : Rithmic Trading / Logon error received from server / Date-Time |
| [2020-06-03 16:56:15] |
| John - SC Support - Posts: 47854 |
Refer to the information here: Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
