Date/Time: Fri, 07 Feb 2025 14:12:06 +0000
Realtime on one PC, histrocial on second
View Count: 597
[2020-06-03 13:57:08]
User551647 - Posts: 23
Dear Sierra Team,
If I subscribed realtime data through the Sierra realtime and/or Denali realtime data feed and if I used Sierra on two PCs, I understand that only one system gets the realtime data and the other can get the delayed historical data feed at the same time.
So my question is, is there any way to control that one specific PC of the two PCs gets the realtime data? Or will the first to log-on receive the realtime data and the second the historical delayed data?
So my goal would be that one specific machine gets the realtime data and the other one the histrocial data, both would log-in based on the same Sierra username, also this assignment of realtime and histrorical data should be independent from the order in which the systems log-in.
Thank you very much and best regards,
Date Time Of Last Edit: 2020-06-04 07:23:08
[2020-06-04 07:23:03]
Actually, you can control it by removing the selection for Allow Support for Sierra Chart Data Feeds on the system that you want to only receive the Historical/Delayed data.
Refer to the information for this setting here:
Data/Trade Service Settings: Allow Support for Sierra Chart Data Feeds (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings)
Also be aware the streaming delayed data feed only applies to the CME group of exchanges. Not to other exchanges.
Date Time Of Last Edit: 2020-06-04 07:24:00
